Coolant light flashing and oil temp high
(In Topic #188263)
Today drove for 10mins oil temp went to 142c and coolant light flashing. Rad fan didn't kick in.
Pulled over waited 20mins to cool down, happened again, drove on further then completely went back to normal temperature wise oil 68c and coolant just below half.
My suspicion is thermostat got stuck, couldn't flow water through rad - meaning oil temp went high?! Fan on the rad not working I'm assuming is the sensor?
temps seem a bit low, you want 1/2 on gauge and oil temp around 90-100 when fully warmed up, maybe stat is missign or playing up like you say
drained coolant replaced thermostat, coolant, fan sensor and coolant level sensor. All perfect and working a treat. The oil temp never gets above 74c, shouldn't matter I've got samco hoses does it?
Thanks again
adam
