conversion help needed
SamGti said
Oh ok so I can use the mk1 gearbox then. Would it bolt straight onto the engine?
Yes
Thanks again!
the mk2 16v clutch is also the same except the spline hole on the friction disc is bigger with more teeth as the 16v box has a larger input shaft
technically you could just swap friction disc, but chances are the pressure plate and release plates are past their best. you could inspect both the 8v and 16v clutch kits to see if any of it is salvageable though. you may get lucky and find one or both are quite recent
actually with the 16v gearbox check the code, you never know it may have killed its original box and had an 8v box swapped over. if it has and the clutch kit is new/good then you can just bung the mk1 box on and go (you still cant use a mk2 1.8 8v box without changing flanges on it, or changing shafts to mk1 cab/rocco 100mm jobbers)
