Weber 36tlp service how to?
Recieved my weber tlp service kit today and although i have had it apart not 100% where everything should go, small o rings, new screws, small filter etc. Is there an installation/service guide anywhere as i cant seem to find one
Lee
Keep on Dubbin
I've just done a 32/34 DMTL and that came with no instructions. Check that all the parts supplied are needed for your carb as mine had several bits left over as there's different versions of my carb.
Webers are pretty simple so if you can't find a service guide then just take some pics before dismantling.  The hardest bit on mine was getting the return springs back on and ensuring the throttle plates didn't bind.
Haynes do a specific weber carb manual.
Thanks jayc. Just a couple of small green o rings, little filter and small rectangular gasket im unsure of. Just hoping someone can help. Scratching my head. Dont wont to remove parts incase seals etc arent in the kit!!!
Keep on Dubbin
The small green o rings on mine went on the idle mixture screw.
