mk1 golf gti 8v
(In Topic #186076)
hesitation on accelaration
What type of unleaded are you using, super or normal and did you tell the chap tuning the car what type of fuel you are using?
Your revs sound right to me, mine stays at 950 rpm when then engine is cold or hot.
Problems with hot starting could be down to the accumulator, it's a valve that hold fuel pressure once the engine is turned off, theres lots of info on here about hot starting problems and the accumulator.
its dead easy all you do is hook up your inductive timing light over spark plug lead #1 (timing belt end), unscrew the plastic bung from the top of the gearbox bell housing then run engine till warm. disconnect and plug the vacuum pipe to the dizzy then point your light into the hole and look for the marks, you want to see the big diamond lining up. if not loosen the 13mm bolt on the dizzy and twist it slowly till it lines up.
edit: you might want to turn the engine over by hand first till you find the diamond then paint it with tipex so its easier to see!
this is what you should see:
6 degrees is reasonably mild in terms of engine tuning, you can usually get a couple more degrees of advance on them before it starts pinking
if you can find a place that sells 4 star leaded fuel these days then by all means use it if you dont mind killing the environment slightly more than you would runnign super unleaded
if you detune the engine you can run it on normal unleaded, but you'll loose power!
Looks like this, slightly different ones depending on year of the car.
http://www.ebay.co.uk/itm/MK1-Golf-Super-Premium-Petrol-Sticker-263-/181288635487?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2a35a50c5f
when driving keep an ear out of any pinking when the engine is under load eg 5th gear and low revs driving up a hill etc. If you do get any pinking retart the timing a little.
keep us updated and glad you have sorted it.
however, if when everythign was at tdc the punch mark wasnt liend up your belt could be out, BUT you'll find that the flywheel moves loads for only a tiny movement on the crank bolt.
so if you double check the base belt timing set the engien to tdc, then see what the flywheel is at. if slightly off move the crank till the punch mark is lined up, then check the cam see if its out or not. It'll probably be fine though, as i say its amazing how much the flywheel moves when you move the crank pulley a tiny smidgeon
So worth double checking the timing marks for the cam shaft.
I think it should line up with the top of the head not the top of the rocker cover as that's what I did with my cam belt change, or it could of been the other way around hopefully rubjonny will let us know.
if you have to adjust spin the engine round 360 degrees and recheck to be sure. taking the plugs out helps when turning over by hand as you dont have to fight compression then
