Help needed ASAP please!
(In Topic #185491)
Car not running!
My car broke down on Monday which the RAC diagnosed as a problem with the fuel pump...
What I have done so far;
- Replaced fuel pump with brand new one - car didn't startDiagnosed problem with wiring, ran a wire straight from the battery to fuel pump. Fuel pump works however car still didn't startFound fuel reaches the metering head with pressure however doesn't get through to the injectors which looks to be the problem
Any help is appreciated! I am based in Bristol so if anyone knows of any garages that will also be useful.
Thanks in advance!
My 1985 1.8 GTI Cabriolet.
Ben Gilbert.
Ben Gilbert.
If I remember correctly on the black, square block where each fuel line connects, there's a small filter under each connection?? If so, these could be blocked.
You could try these guys - Waterwerks - Home
In Bristol - Tom is mostly on the MK2 Golf forum but a top bloke so am sure could help you if you get stuck as he'll know K-Jet
Hairyarse, I've contacted that guy on Facebook who has come up with a few suggestions - thanks for that!
Rich, I checked the plunger and it seems to be fine.. The metering head was working Monday so don't think it'll be this…
Cheers again
Ben Gilbert.
Ben Gilbert.
