help,,,,, does a golf mk1 gti cabriolet 1.8 k jet engine have a idle control vale
the car splutters on start up and dies but once she is running she drives fine but when i stop the engine fevs up and down any ideas
87 on have a stabiliser, mounted on the drivers suspension turret.
Sent from my iPad using Tapatalk
Regards Volkswarren
X2 1983 A REG EW CAMPAIGN In WHITE(Awaiting full rebuild solid body) :thumbs: & T Reg S1 GTi Project, Still Looking for Series 1 GTi's or a 16S Oettinger to restore (Complete Cars only)  or an A reg Lhasa Green or White Gti to restore, also consider  Black, Red or Blue, Also Golf Driver Project Wanted anything considered WHY
They have an auxiliary air valve on the back of the plenum, a bimetallic disk that closes off the air with heat.
Might be a simple as a perished rubber seal or carboned up idle screw on the back of the throttle body, take it out and check the seal and clean it.
Cheers,
Ade
The auxiliary air valve only "works" during warm up. Its purpose is to increase the idle speed (slightly) during initial warm up. On the "plenum" there are two adjustments. Firstly an "air" screw, not easily seen at first because its fairly hidden ! If you see where the throttle cable attaches then look "down the back" you should see a brass coloured screw with maybe a hex top. I used a 8mm to adjust (if I remember). There is also a "base idle" adjustment on the plenum ... Basically there is a micro switch that should be closed on the "over run" (throttle closed) if the adjustment is correct you can just hear the switch clicking, as you close the throttle .....
7mm on mine
Regards Volkswarren
Ah ! I wondered what that was !
Adjust the idle speed up to 1200 rpm then lower it to 950-1000 rpm using the idle screw at the back of the throttle body. You may have a perished idle screw rubber which is making the idle screw lose and it adjusts the idle speed on its own.
old flat rubber.
new o ring fitted.
Last edit: by mark1gls
