Fuel Pump Issue??
(In Topic #203741)
Hi All
I am having a bit of trouble with my golf. It drives away fine but there is a whine coming from the rear of the drivers side. Then after a while the car will cut out but will start again no problem.
when it cuts its starts screaming / whining from by the rear wheel on the drivers side.
Any ideas? Fuel pump?
Denis
Denis
If it's a GTI, that sounds like the fuel pump. Is yours early or late? Later (cabby) models have the lift pump in the tank, if that fails it puts more strain on the main pump, until it kills it.
2001 Zafira 1.8
2001 Zafira 1.8
Yep agree with the above. When I had my cabby I had to have both replaced. Replaced the main fuel pump and couldn't work out why there was still an issue. Turned out to be the lift pump as well - as already mentioned.
Lift pump inside the fuel tank is failing and making the main pump underneath the car work hard to get the petrol out of the fuel tank.
New lift pump is the cheaper option to replace so I would start there 1st.
http://www.ebay.co.uk/itm/VW-GOLF-MK1-CABRIOLET-MK2-GTI-8v-16v-FUEL-PUMP-LIFT-PUMP-IN-TANK-C246-/200691149226?fits=Model%3AGolf&hash=item2eba1fe9aa:g:VV4AAOSwMzVTw6~7
