Wipers/gauges
you shouldnt have the red and black to the same pin though…
as for rear wash/wipe this should be on its own fuse and relay above the fusebox so im pretty sure this isnt why the fuse is blowing.
the 11 fuse also powers the horn relay which is clipepd above the fusebox so thats worth a look
Where about is the fuel pump relay I had it started today, would it still start without these connected ?
Lol going to get to the bottom of this need the wash wipe at the front as for the mot but have come in doors now will have another look tomorrow thanks again john appreciate all your help, really do if you was here I would made you a cuppa and packet of my favourite milk chocolate digestives ( now that's some thing special lmao )
if this relay is nowhere to be found…. then this could be the real reason the 11 fuse keeps blowing
The wipers work fine the horn works fine the vdo clocks are ok but as soon as I press the wash wipe it blows a fuse now, I have got a new wiper stalk, but as soon as I press wash/wipe pop goes the fuse for number 11, and I have got 16a ceramic fuse on there the brown wire from the wash pump however looks like it's connected to the indictors il take a picture and show you guys hope some light can be shined upon this as I want to get the mot done thanks
Where do I look now, is there anyway to have its own connection, the stalk is new this looks a problem someone tried to hide as the clip that pulls the connectors was broken so I is thinking someone must if broken this off so I couldn't be activated and blew fuses mmmm interesting,
Lol but it's not going to get me my mot so need to sort it is there any way in getting around this, would it still be a horn relay because the horn still work so can this be ok and just for a guidence which one is the relay for wipers
look at that green wire, looks to be crimped to a brown then earthed to the slam panel? not ideal you want it tapped into one of the browns in the light loom on that side so it earths back to the battery properly.
i think now you'll have to get under the dash to check the stalk wiring, plus follow the wiper motor wirign front and back. a top suspect is the wiring to the rear motor where it runs thru the rubber boot between tailgate to body. A quick way to bypass it is unplug the joining connection at the back of the car near the rear lights, look for a grey/black and green/black 2 pin plug, disconnect that to completely disable the rear wiper loom and bypass any possible wire damage in the tailgate
For lose connections but nothing, any other suggestions, thanks again sorry to be a pain but just need to sort it
you should have ign live at the black/grey, earth at the brown then to get the wiper going you need a live pulse from the stalk/relay at the green/black. take care, the linkage may catch your fingers!!!
for the fuse blow you'll just have to dig into the wiring, happy fun fun
what wire colour is it onto that pin you removed?
As my front is wash/wiping it will go through it's mot thanks again john for all the help you have given appriciate it
