What should this be plugged into?
(In Topic #192491)
One of the things I found was this 4 pin plug, over on the drivers side to the right of the clocks.
Where does it go? Can I remove it if it's redundant?
It's an 87 cab btw.
golfcabrio said
Cheers for that
rubjonny said
looks aftermarket to me, can you take a pic of it at an angle though? trace it back and it'll probably run to an old alarm or immobiliser brain
That makes sense, probably from my old Clifford alarm then! I'd like to remove it just to tidy up the wiring as much as possible, so I'll have another look later and let you know if I find anything. Cheers!
Can I also cut this box out? Or will it affect my stereo? I don't have a power antenna anymore, so not worried about that
Thanks so much for your help so far, appreciate it Here's the box
Last edit: by Ellface
So I've cut it out, and now have no more wires that don't connect to anything!
Cheers for your help, just gotta get some loom tape and tidy it all up before the dash goes back together
