Temperature Gauge
(In Topic #198078)
In the morning, I switch the ignition on and the gauge goes to a bit over 3/4 and I hadn't started the engine.
Is the problem the temperature sensor or something else?
It is odd that it happened the way it did.
I had a very similar problem years ago with the sender wire earthing where it was touching the rocker cover because of dodgy insulation (albeit on a mk1 Astra rather than a Golf!)
if its a GTI theres a coolant level warning relay 42 or 43 above the fusebox which is also tapped into the coolant temp wire, pull it out and check it for damage plus the wirign to the relay socket
