Sparking issues Mk1 gti '83
(In Topic #186108)
Now getting the car to stage of putting a replacement front panel in and wanting to start the car.
Not getting any spark from the main lead from the coil when turning the engine over. The coil is wired up correctly, and I have thoroughly cleaned the 3-wire connector into the dizzy and cleaned up the cap.
Have replaced the coil, and the module.
At present when key is turned to first position, I get the fuel pump constantly whirring (louder than previous I swear) and the oil pressure buzzer sounding in the cockpit.
The only time I get a spark is when the key is in position 1 when using a power probe from the battery and earthing the coil.
Does this suggest the distributor is knackered?
Many thanks! Now I have a working spare coil, and module…!!!
