Running a wire through the car
Can't seen to move it or even destroy it with such a tiny hole.
'83 1.3 Golf Driver GT - Project thread
Instagram - matt.semp
mazza whats the part number? dunoo if its just the angle of the pic but it does look a bit taller than the one in rich's pic
rubjonny said
does fuel still flow nicely out of the outlet on the bottom of the tank? if so you could use a facet pump or whatever on that outlet to fill the swirl pot. just a case of is there room underneath…
Yesterday I heated up a blade and hot cut the sides of the swirl pot.
I found my multitool was broken so couldn't use the flexi shaft and cutting disc.
Going to machinemart in a bit to get a drill flexi shaft which should do the trick.
To anyone else please don't use anything red hot in the fuel tank unless you know for certain it contains no fuel!!!
I was OK as this had been restored by a company who cleaned the tank and lined it with an anti rusting compound.
John is right, mine is not as tall as your picture. I will get a better shot later
mazza411 said
It is a different part number but I have chopped it up and bent the pins because it was miles too tall and it is now just squished down and it works fine, I know this because it fired up first time
Great news
I wish I was having more good news lol got to finish butchering the swirl pot to fit my lift pump!
Nothing is ever straight forward is it!?
I do however have another sender which has the outlets pointing diagonally outwards towards the connector plug which is horizontal not vertical like the sender you have. I'm really confused about this as the original senders connector doesn't fit anymore.
I could use the other sender but that would be cheating :p
Polo sender?
This is the sender which seems to work OK as the putlets are pointing towards the engine and the connector is at the front giving you clearance.
Cabriolet sender?
I'm sure you could get the Polo sender right with some tweaking but as I have the cabriolet one it makes it easier.
I have just switched everything over to the cabriolet sender for simplicity.
it seems to be very similar to my old one when its at 1/4 tank (roughly 150 miles) so might just leave it for now mayvbe get a cabby one and another connector in the future
What slim line clips can I use instead?
pretty sure thats what would have been used originally on the cabrio senders too
