Rewiring Mk1 Golf
otherwise match the plug colours to the thermoswitch colours for the grey and red thermoswitches, chop plugs off and crimp spades. the black plug is for the dash temp, find the single pin black sensor on the front or side flange. chop plug and crimp a spade to the red/yellow, the brown is no longer needed.
yellow and black/yellow is for the dimdip resistor, ignore. yellow/white and brown is for front fogs
green/red and brown is windscreen washer pump
black wire spade is ignition live for carb heater, should be a spade on carb loom for it. the red/white spade goes to the inlet heater, can see matching spade to the right of the inlet. other random pcarb plugs on your engine loom not needed on a weber carb
red and brown is radiator fan, shoudl be matchign plug on the rad fan loom. unless its an early car then the wires were hardwired to the lighting loom. crimp spades on. red is perm live to the rad fan thermoswitch, brown is earth for the fan motor
No doubt i will have more questions soon
Is there any way i can wire this into the new loom/fuse box.
I forgot to mention I have upgraded from the s1 fusebox to the s2 and loom, if that makes a difference.
Im on to the dash loom now and its pretty straight forward although ive got a couple of connections on the fuse box end Im not sure of and just want to check with before I fit the fuse box in.
1. yellow one I think runs to the long instrument panel plug
2. grey/green + blue/grey run to the strange plug in the bottom photo, this is around the headlight/dimmer switch area.
3. grey/yellow has a strange plug on the fusebox end
2. oil pressure switch, should be a female spade on engine loom that plugs to this and goes to the 0.3bar switch on side of the head
3. handbrake switch connector, matchmaking plug from the handbrake switch
4. brake fluid/handbrake warning light
Should I just cut and join avoiding the fusebox plug or tap into it? ……if that makes sense.
Thanks for your help
