OEM Cigarette lighter
(In Topic #182337)
Can you buy original cigarette lighters?
I recently bought a new socket for my T4 which had a connector on the back. I cant remember what it looked like but it was a 3 pin plug an play thing similar to the on in the mk1. Not sure one will fit. I dont fancy pulling the one out of the T4 dash to try it as it was a complete knacker to get in and out.
I have found this which is the same as the one for the T4 but it hasn't got the mk1 listed but it has the mk2, 3 and 4 plus a load of other VW's
http://www.veedubmachine.co.uk/lighter-socket-vw-golf-passat-polo-bora-t4-t5-toledo-fabia-p-97.html
Can anyone point me in the direction of one for the mk1?
The cigarete lighter on the mk1 is listed as part no: 1J0919307
The 3pin connector on the Mk1 is listed as: Flat contact housing part no: 191919321
The T4 is listed as the same!
Looks like they used the same lighter socket for the whole range.
rubjonny said
i think what it could be is you are missing the short run of loom between the dash connector and the ciggy lighter?
I bought a new section which is the short bit between the main loom and the lighter. I think the lighter is an aftermarket one as it's got individual spade connections on the back and not a connector that matches the piece of loom. I ordered the one above and hopefully it will fit the loom.
