Odd Electrical Issue
(In Topic #201186)
Indicators and this wire from the forward bulkhead
I have 1 electrical problem and another involving a wierd set of wires.
Indicators.
my hazard warning lights work fine when the switch on the dash is pressed, my problem occurs when i use the indicators right or left, nothing happens, neither front or rear light up, but what is odd is when the indicator stalk is off, the indicator lamp of the dash glows a little, like there is low power to the bulb. Any idea's how i can get these indicators to work ?
Odd Wires.
Does anyone have these two wires that come out of a rubber grommet on the bulkhead on the passenger side ( black and brown ), the length is about 40 cm, where do these connect to ?
Indicators.
Odd Wires.
Current VW Own : 1991 VW Golf Mk1 Clipper Cabriolet 1.8 Former VW Owns : 1968 Early VW Type 3 Fastback 1600TL 1969 VW Beetle 1500 Deluxe 1972 VW Beetle 1200 1970 VW Type 2 Devon Bay Camper 1973 VW Type 2 Westfalia Camper 1970 VW Beetle 1200
check fuse 19, and make sure the black/blue ignition live wire hasnt fallen off the back fo the hazard switch
if its a later cabby those wires may be for the heated washer jets, pics?
Relay 21 was only working on Hazards but not on indicators. replaced relay 21 from seller I trust on the bay. All working now.
Seller as follows :
http://www.ebay.co.uk/itm/200648739176?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Seller as follows :
