Ignition problems?
(In Topic #196761)
Last edit: by Assichtgut
Depening on which fuel you want to use will affect the timing.
The GTi it's meant to run on 98 RON octane rated petrol (There should be a sticker on the car saying this) all other engines, 1.1, 1.3, 1.5 and 1.6 carb will run on 95 RON normal unleaded petrol.
The GTi will run on normanl unleaded but the power will be down and tick over may be a little lumpy and you may find the MPG is lower.
It is really easy for the cam belt to be a tooth out and the car will sort of run, I would check those marks.
