Fuel pump relay
(In Topic #209606)
Fuel pump relay
is it the wrong one ? Thanks
The list of correct relays are at www.cabby-info.com
http://www.cabby-info.com/Files/Relays.pdf
Fuel pump relay
On the drive
Myvalver 89 GTi Grey mk2 16v
Where is the fuel pump relay, fitted above the fuse box or in the main fuse box with all the other relays?
My later style fuse box from 1988 cabriolet, blade fuses, relay with no62 is my fuel pump relay.
Fuel pump relay
gafo said
Alright Kenneth are you boasting again about your 3 cabby? Yes that's the part no I'm going with off the toasted relay. Cheers mark mines in same position, I bridged terminals on fuse box and pump came on do happy days it's not busted
Haha not boasting..otherwise I'd say 3 running..1 donor…1 in a paint shop what did run and a mk2 16v… and still i dont really have a clue when any will be finished.. glad you identifed the issue..and that you've got a pair of relay coming(1 spare) unless happy with wire bypass . Now just to confirm that everything else is good.
On the drive
http://www.ebay.co.uk/itm/VW-Audi-Seat-Skoda-relay-No-62-443907385B-443-907-385-B-/272552153569?hash=item3f755fd1e1:m:mdjohYWAXK2cctBoERgLwtg
No62 relay has a rev limiter built into it and is used in later cars.
There was a guide on here some where about what the different relays fit and do.
I've tried a new repo relay and it was rubbish quality and my fuel pump primed every time I turned the ignition on which I did not want so I found a 2nd hand relay and its back to how it was before, no priming.
2nd one is for the older ceramic fusebox which is why it wont fit.
Fuel pump relay
Fuel pump relay
2 = 443906059A/321906059D/E = no limiter (superceeded by 321906059F)
3 = 443906059 = no limiter (superceeded by 321906059E/F)
62 = 443907385B/321906059G / 24.1400.30 & 3.300.220 / ? = 6.5k limiter
63 = 321906059F / 24.1400.20 / 935VG0090 = no limiter
65 = 321906059H / 24.1400.40 & 3.300.230 / 935VG0080? = 6.3k limiter
Fuel pump relay
Sorry for what might seem like a really silly question!!
My 1990 Mk1 Cabriolet (DX engine code) is currently broken at a local garage. Fuel pump not priming at all I believe, mechanic has traced fault to damage on fuse board following what appears to be a corroded fuse that has spread to the board.
I need a new fuel pump relay fuse but I'm confused as VW Heritage has two types that both fit my car. The relay from the car has come from position "2" and just has the marking of 1902 !
I need to source a new board and new relay but I am unsure on what relay I need please??
1990 - Cabriolet GTI 1.8 (DX)
They can test the fuel pump etc by removing the relay below the fuel pump relay and putting it in the slot for the fuel pump relay then the pump should run as soon as the ignition is switched on.
Other way is get a bit of wire and bridge the 2 bigger connection where the fuel pump relay is then the fuel pump should run even without the key in the car.
https://www.classic-vw.co.uk/
Think buy 2 as a spare should always be in your tool kit.
On the drive
Fuel pump relay
Place of the relay
