DX engine Microswitch
(In Topic #193577)
Does anyone know where I can get the microswitch that sits on the underside of the throttle body of a 8valve DX engine. This switch controls the throttle enrichment when the engine is cold. Mine has lost the little tit that operates the switch. The switch is always s/circuit consequently messes up the mixture. I am having trouble getting the engine to tick over until its warmed up and apart from the air bypass valve (which I haven`t taken out yet) this is the only thing I have found not working. The switch has a green cable moulded into it and a 2 pin socket on the end.
I have tried to fit alternatives but the spacing to the metal support bracket is non standard.
The lump is in a `89 rocco which I got hold of recently and am in the process of overhauling for my wife to use as her daily ride. Her current Rocco (`91) has 200,000+ miles and is getting tired. This one will replace hers and I would be rebuilding her old car as a project in the summer.
I hope someone can help
Best Wishes
Gerry
I may have one but will have to check its still attached to the spare inlet manifold I have.
A fellow Scirocco owner..
have a look thru this thread, ignore the 16v specific stuff just look at the kjet bits:
http://www.vwgolfmk2.co.uk/forum/viewtopic.php?f=37&t=25972
Best Wishes
Gerry
Last edit: by mark1gls
