Custom Speedo HELP
(In Topic #223373)
Right My clocks are complete knackered on my mk1 golf, so instead of replacing it with another second hand unit I want to go the Custom route and get rid of the full pinnacle.
My question is where can I buy a stand alone Speedo and which type would fit straight to my exsisting cable or do i need do go custom speedo cable and drive as well and where would I get them from aswell?
1983 GTI-Black
MY very first one AND LOVING IT!!!!!
How about forgetting about the speedo cable and getting something that gets its signal from a satellite. No idea how good or bad they are, was just something i was beginning to think about..
for electronic clusters you can fit a speedo sender from mk3/4 gearbox to mk1 to sort that side. rev counter will often be low amp signal if you have electronic ignition carb/kjet you can get this signal from pin 7 on the spark module in scuttle.
mk2 golf clocks are a close fit to mk1, slightly less scene taxed and just brackets modded slightly plus need a bit of wire splicing to fit
