Correct horns for a series 1 GTI
(In Topic #188907)
which ones?
Snail type
Disc type
Like some others I'm having trouble getting two working. I thought it was down to old/deteriorated wiring but the muiltimeter says otherwise.
Does the disc type draw fewer amps than the snail type, I was wondering if I'd have better luck trying two disc type horns?
If you have 2 horns you need a relay which switches the earth side of the horns, this is clipped above the fusebox on an S1 GTI and is wired direct to the horn button brown/blue wire. the output side goes to E/11, then horn earth to A/7. the input sde is earthed above the fusebox
the steering rack earth is a good one for failing, this is the earth for the horn button, though if the relay clicks when button pressed it isnt down to that
Life Member
Don't forget the brass ring and spring clip under the steering wheel rubs away so possibly why it's intermittent. Try the horn with the wheel in different positions, see if that helps. It did for mine so I've left the wheel at a slightly off set angle.
also the earth for the steering rack is in the engine bay, look on the steering rack itself there should be a short earht wire from a screw on the rack to the chassis
I see you have a picture in the thread can you still buy them new?
mark1gls said
I've got twin disc horns fitted to a bar then attached to the car on my 1978 Mk1 Scirocco and they are fitted as standard, each horn makes a different sound, one low and one a higher note.
That is good to know, I suspected that might be the case. I think you can still buy them - I googled for those pics.
