ABF CONVERSION
(In Topic #189433)
rogue wires
but im mechanical
red/white and red in 1 terminal sounds like power for the injectors and lambda heater, this would plug into male spade on E/14
black/green sounds liek oil temp sensor, male spade to dash loom
brown/white sounds liek earth to head for MFA cluster, again matchign male spade in dash loom
2 reds in 1 spade not so sure, if it has the ecu relay above the fusebox then it will have 1 red for that but not usually 2, unless the diagnostic port power also crimped to that…
for coil black goes to coil pin + or 15, black/red to coil - or 1
(Brad did I buys some shocks and a gti tank off you earlier this. Year?)
I traced the 2 reds and your spot on they go to relay (53) and to the port.
Only wire I have loose from my dash harness is grey/yellow ?
Only issue is temp gauge runs up and light flash virtually straight away, so I'm guessing I should check sender isn't earthing? I wanted to run a top fill for looks, and the plumbing on my Abf has no t piece for the exp tank breather so I just blocked the pipe that goes to the bottom of the ecp tank which I'm guessing won't help? Could this be the cause? Cheers
for the gauge take the red/yellow wire off the sensor in the side of the head and see if that stops it, if it does then change the sensor (the mk1 sensor off the old engine is the same) if not chase the wiring to it back its shorted to ground somewhere
for the idle make sure you have all the connections on the throttle capped off and your ecu is either on the nipple on back of inlet or one of the nipples on your brake servo hose. there a nipple on side of inlet for the fpr on fuel rail plus another one thats easy to miss which is on the front of the inlet near the rail/isv which goes to the side of the PCV valve
Yeah got my ecu vac on the TB and the back one blocked so will swap, and work through the rest and update. Bigg thanks.
bit you want is far right of this here piccy:
Thanks for your help, got a lot of bits left over from a mk1 4 door that I bought as a donor, had some kr stuff with it, let me know if I can help u out.
for the rocker gasket vw recommend a smear of sealant at the corners of the humps over the dizzy and timing belt sprocker, plus a bit on the half moon pieces. the selant they recommend is the same as the stuff used to seal later vw sumps
