1979 Rabbit Fuel injected - Cold start ignition relay ID Needed:
(In Topic #166445)
I hope I am in the right area of the forum and hope that someone with more know how can help me here.
I have a 1979 Rabbit Convertible, 1.6 engine, Fuel Injected model.
The real major problem I have here, Down here in Perth , Oz, there is limited product knowledge and parts sourcing.
Since getting the car just over a year ago, I have redone the head.
The major issue now, is I can't either locate or correctly identify which " Cold Start Ignition Relay" , applies to this car.
Have done the net search and Ebay as best I can but come up with no real info or obtaining a relay to suit.
There has to be some information or factory specs that correctly identifies the part and correct part number, or an OEM replacement as such.
So really need help here or info as to where I can buy one, so I can get the girl on the road.
I have attached a pic of the fuse box as to the type it is and where does the relay actually locate to.
Also are there other relays available from these sources.
Many thanks in advance
