WIndscreen drain question?
Took my windscreen out the other day, and repaired a few holes.
However the one question I had was…….      Does the Scuttle panel have a drain hole in the centre under the windscreen rubber and does any one have a picture of it?
I should of taken a picture of it, but had to get the windscreen back in due to the weather.   I just want to make sure I return it to the correct size and shape due to the rust around it,  if it exists in the first place,
Thanks in advance
Anyone ?
Could you please explain why you're asking, what the issue is?
Oh and I don't know either because when mine was removed I wasn't there to see it but maybe another member will understand!  :thumbs:
As above I removed my screen and repaired a few holes. However as I had as lot of rust around the centre hole under the rubber, I had to guess what size and shape it was and if it originally had one.
So, I just wanted a picture of the flange of the scuttle panel that the rubber sits in (bottom centre),  to check what needs to be rebuilt there.
Ive done a good search, but can't find any decent pictures.
Don't have any pictures and its been a few years since ive seen under a rubber, but I don't think there is a drain hole under there. Best wait for confirmation though.
I was thinking the same but didn't want to put my big foot in it!   ;)
I welded and sealed the other holes I found, but this one was dead centre and looked to have straight sides as if it was pre formed.
It was badly corroded and I made a clean repair and left a hole in it.
If anyone can 100% confirm if a drain hole is normally there or not that would be great.
If not the screen and the welder will be out again.
I took this picture for another thread…
Here's the area with the hole magnified a little…
That's perfect,
Many thanks, that answers the problem.
Think I need to close the he up a bit more.
