Front Panel options
Hi Guys,
I have collected all the bits for my shell to rebuild it except for a front panel.
I see VW Heritage are sellling non genuine ones, are they any good or is there a recomendation on the a vendor to use for a better fitting panel?
Front Panel options
Never used one of there's sorry
Regards Volkswarren
X2 1983 A REG EW CAMPAIGN In WHITE(Awaiting full rebuild solid body) :thumbs: & T Reg S1 GTi Project, Still Looking for Series 1 GTi's or a 16S Oettinger to restore (Complete Cars only)  or an A reg Lhasa Green or White Gti to restore, also consider  Black, Red or Blue, Also Golf Driver Project Wanted anything considered WHY
Only heard good things, I'm going to fitting one soon so will tell you how I get on! ✌🏽️
Mine fits really well!!!
Excellent, Thanks for the pics, order is going in tonight.
how do you remove the front panel  ?  mine neds replacing
Drill the spot welds out along the around the inner wings, cut it free from the chassis legs and it's off! That makes it sound really easy but getting it off the chassis legs isn't the easiest of things but once a that's out the way it's plain sailing! Get the new one in place, clamp it up and weld away! Retrofication make a cross member brace, I'd suggest buying one then you can bolt it in before welding so you know everything is central! ✌🏽️
Looks good. Just removing wings from my donor. Can't believe how much effort needed to remove sealer..makes me wonder why used bolts. But seeing how well your front panel has gone all is not lost on donor car.
On the drive
Myvalver 89 GTi Grey mk2 16v
