Damn Spotlights
(In Topic #183829)
Incorrect brackets
This is now the 2nd set I have purchased and they have failed to fit, so I am wondering if anyone knows whether I can take the glass off the ones I have which are smashed and then somehow remove the glass off the ones I purchased and re-bond them?
Answer is probably no, but I thought I would ask!
Pete
COTM Team
I put an argos catalogue on top of mine to hold it down, worked a treat and still held for over 2 years
hope helps
aircooled1968 said
you can remove the glass, pop the oven on and stick em in for about 10 mins, remove from oven carefully as they gonna be hot, prise the glass off very carefully by running a flat head screwdriver all round it (twist it in various places) once glass removed, clean edges and refit onto old units with a bead of silicone sealer, squash back together and let it dry over night.
hope helps
Thanks very much, will give it a go, obviously when the wife is out!
Pete
COTM Team
