cabriolet rear window frame replacement ??
(In Topic #166852)
hi,
has anyone any idea the job involved in replacing the rear window frame on a cabriolet hood?,is it a straightforward job?would appreciate any information off anyone.
thanks.
thanks.
COTM Team
have a look through this, may help, i did mine when i changed roof, dont know if can be done without removal of top
http://vwgolfmk1.org.uk/data/attachment.php?id=472&filtered=1
Staight forward job if you are fitting a new roof skin, undo the 4 bolts at the bottom and slide out the 2 plastic pegs at the top which are fitted the the webbing which runs to the front of the roof. Can't imagine its possible without a new roof as the roof is stapled to the window frame.
How old is your roof?
i have only had the car 6 months,roof is excellent,not very old.looks as though somebody has fitted the old rusty frame back into the new roof !!
so i want to replace the window frame only,any ideas would be appreciated.
thanks.
thanks.
ok thanks,i need to replace the only the window frame.
any ideas ??
I did mine about 6 months ago. Like you the hood was brand new but the window frame was rotten
You simple in bolt it and remove the staples that hold it in. Replace it and use a proper stapler with long staples to attach the hood fabric to the new frame.
Don't forget to use sealant all around the window as you fit the rubber seal.
If you follow the instructions on here for replacing the hood (just the rear window bit obviously) you can't go wrong. It took be about 3 hours.
I had the same issue on mine.
I'm not good at stuff like this so gave it to Classic Car Services in Thurmaston to sort out and crazyquiffs supplied the new frame…
Currently Mk1less!
Currently Mk1less!
