cabriolet rear window frame replacement ??
(In Topic #166852)
has anyone any idea the job involved in replacing the rear window frame on a cabriolet hood?,is it a straightforward job?would appreciate any information off anyone.
thanks.
COTM Team
http://vwgolfmk1.org.uk/data/attachment.php?id=472&filtered=1
How old is your roof?
so i want to replace the window frame only,any ideas would be appreciated.
thanks.
aircooled1968 said
have a look through this, may help, i did mine when i changed roof, dont know if can be done without removal of top
ok thanks,i need to replace the only the window frame.
any ideas ??
You simple in bolt it and remove the staples that hold it in. Replace it and use a proper stapler with long staples to attach the hood fabric to the new frame.
Don't forget to use sealant all around the window as you fit the rubber seal.
If you follow the instructions on here for replacing the hood (just the rear window bit obviously) you can't go wrong. It took be about 3 hours.
I'm not good at stuff like this so gave it to Classic Car Services in Thurmaston to sort out and crazyquiffs supplied the new frame…
Currently Mk1less!
Currently Mk1less!
