cabby roof gap!
(In Topic #183301)
It may need the J hooks by the locking handles adjusting to pull the header onto the windscreen frame seal tighter.
you'll need some good high temp impact adhesive to do the job, for this one you'll probably find the brush on stuff is easier.
to do this open roof and you'll see a metal retaining strip all the way along held on with screws. remove that then carefully peel the material away from the header rail and clean off all the old glue. apply more glue to both surfaces and leave it a bit to go off then refit the material. be sure to pull the edge lip over so its kinda tucked under the edge of the metal roof lip if that makes sense? that what it should make better contact with the rubber seal on the windscreen
best pic I have of mine:
Plus there looks like a dip or hollow at the front behind the header of the frame. There's usually a filler strip that fits there. Some fitters don't glue the front down either.
It may well need gluing and a bit fettle.
