what six speed box for and agu?
(In Topic #194868)
Old dubs never die, they just get lower
if you can find one the 02s box from lower power mk5+ golf is almost straight fit, just need to change bellhousing for 02j one and flanges for 100mm, then its direct bolt in with mk1 02j mounts
only thing is ratio wise they may not be great so would have to shop around to find one, then look up the code to see what ratio it is. could be a good basis for 02j gear swaps though depending what gears are poor as 1st and 3rd are part of the shaft input shaft plus the final drive is part of the output shaft and so cannot be changed but the rest can
