1983 MK1 cab 2E conversion
(In Topic #205296)
i'm a frenchy happy mk1 cab carb owner. I do lot of work on my lovely car!
i' do mk3 2E swap engine and i need electrical help to finish my swap... The mechanical part is ok for me but i'm a poor electrician ^^i have a mk2 fuel pump + pressure regulator + mk3 plastic fuel lineCE1 fuseboxcomplete 2E motor loom with digifiant ECU + F + G1 + G2 plugs + fuel pump loom.Could you please help me for wiring diagram.All The best!PS:Sorry for my bad english
280mm front brakes upgrade
rear disk brakes upgrade
coilovers
lower bar
PU bushes...
i found informations on rubjonny google drive:
as my mk3 is a CE2 fusebox. did forgot i something ? is it correct?
Thank you!
CE1 | CE2 | Function |
D/24 | F/1 | Starter motor pin 50 |
D/4 | F/3 | Alternator D+ (for models with alternator wire in engine loom) |
earthed to chassis | F/4 | Earth for claw above fusebox |
C/18 | F/5 | Starter live for ECU and/or 5th injector thermoswitch |
C/20 | F/6 | reverse switch (mk1 models) |
C/21 | F/7 | reverse switch (mk1 models) |
R/2 | G1/10 | ECU power |
D/26 | G1/12 | Coil -ve / rev counter |
earthed to claw or side of head | G1/2 | Dash outside temp sensor |
D/13 | G1/3 | Fuel pump relay earth trigger |
D/23 | G1/4 | Coil live |
n/a | G1/5 | Dash earth to head |
ECU relay pin 86a | G1/7 | ECU relay socket pin 5 (109 relay 85, 30 relay 86a) |
E/14 | G1/8 | WUR/Lambda heater power |
wired direct to dash | G2/1 | Dash oil temp sensor |
D/21 | G2/10 | Oil pressure warning circuit 1.8bar switch |
D/1 | G2/11 | Oil pressure warning circuit 0.3bar switch |
wired direct to dash | G2/2 | Dash outside temp sensor |
D/29 | G2/3 | Coolant temperature sensor |
D/2 | G2/4 | Ignition live feed to various circuits |
n/a | G2/8 | Fuel pump relay feed, unfused |
earthed to claw | M/1 | Fuel level sender earth |
E/14 | M/2 | Fuel pump power |
E/5 | M/3 | Fuel level sender |
E/14 | Z/1 | Fuel injector power |
N | Z/1 | Carb heater, diesel glowplugs or fuel injector live |
D/22 | Z/2 | main CE1 fusebox earth |
when you do a conversion like this the easiest thing is split the mk1 loom down and keep the non-engine wirign as is, and split the mk3 wirign loom down to remove anything that isnt for the engine. then combine the 2
this thread and link back to this forum should also help you, the coil and ecu relay parts apply to the 2e code as well:
http://www.clubgti.com/showthread.php?249714
Also with Z/1 you can use spade N on the fusebox. Z/1 will even fit N once to trim off the lock peg
I'll keep you informed.
All the best!
