k-jet swap from digifant
(In Topic #185265)
I am converting my mk1 with a PF digifant motor and toltal wire loom from doner car mk2, can i use the k-jet fuel pump instead of digifant. I cant use the tank from the mk 2 with build in pump?
Regards Michael
Regards Michael
the mk2 pump is quite a bit larger, if it will physically fit under there then yeah you can use it no problem feed it from the lifter pump. you can bin off the MK1 plastic fuel reservoir if you fit the mk2 pump too as its all built in
