AUQ 1.8t Fuel Pressure Regulation
(In Topic #170345)
Snagging - 20vt Mk1 Conversion
Hi All
I have just installed an AUQ in my Mk1 Gti and it is overfueling massively, if I clamp the fuel line inbound the engine settles down and idles nice
The original Mk1 1.8 Gti pump is putting out way to much pressure so I thought I could just fit a pressure regulator and gauge pre-engine and this would solve the issue?
I have been told that I also need to fit a blank the original AUQ unit also as the regulator on it's own will not solve the issue, can anyone confirm this please.
Cheers,
Mark
Cheers,
Mark
Would,nt clamping the line reduce volume and not pressure?, and secondly surely any regulator should be in the return line so you get the 3 bar or what ever at the injectors, the other way would only pressurise the fuel line to the correct pressure.
Hi
Apparently the Kjet pump is way to strong and I need to regulate the fuel pressure, at the moment the tickover is about 1200 and the exhaust gas'es read about 7 clicks
Once the line is clamped the engine settles down nicely and exhaust gas comes down to MOT pass of 3-4 ish
Mr MOT man recons I need to blank the original regulator on the fuel line and stick in an adjustable on the return line and turn it right down? (not sure about this though)
Has anyone else had an issue like this or knows of a thread on here I can check?
Cheers!
Cheers!
sounds like the return line is blocked or the fpr is bust, the kjet fuel pump is fine on 20v engines loads of people run them and in fact its actually recommended for big power applications
Thanks for that guys, have ordered a new 4 bar FPR for the AUQ which will land in the morning
Will chuck it in and check the lines and see what happens
Will update then, fingers crossedcf_emoticons__BangHead:
cool fingers crossed, I was runnign a kjet pump on my mk3 abf lump and it was fine, uses same fpr as a mk4 20v
Did the new FPR solve your problem? with my AGU I am using a Bosch fuel pump capable of 500hp (they say) and have never had any problems. Hope you got it sorted!
'82 c formel e - 1.8t 20v
