All red rears DIY for cabby and fog light removal
(In Topic #216401)
In an attempt to tidy up the back of the cab I've decided it would look best with all red rear lights, now because the aftermarket ones are no longer available I've decided to tint spray some original ones
Now the problem I've got is how to make the indicators flash ginger and not red.
The best method would be either green bulbs (which I can't seem to find anywhere) or as Peugeot do and have a green filter inside the lamp.
Green + Red = ginger
Anyone have any input or suggestions of how to achieve this?
2nd part of the plan is to remove the bolt on fog light and replace one of the 2 reverse lights with the fog.
The other reverse light can stay red as they aren't an mot requirement anyway
Has anyone else done this or have any pics of cabs with either of these 2 mods, preferably black small bumpered models
Last edit: by 1985
Current rides:
Your Moderator Team
Sent from my Smartphone
Current rides:
WATERNAIR said
Thanks mate and I'll tell you what, with the day I'm having that really made my brain hurt!
All sorted and you get another bump!
https://www.ebay.co.uk/itm/T11-BA9S-3528-SMD-5-LED-T4W-Car-Front-Rear-Turn-Signal-Dome-Light-Bulbs-DC-12V/263386878947?var=562398926561&hash=item3d5314d3e3:g:I-sAAOSw0W5aMebo
Green bulbs - sorted
Ian
I'll post a snap up before next weekend when I get 5 mins to put them on
Current rides:
Not sure I'm completely happy with them just yet, they need to be a little bit more . . red
Current rides:
Next thing is to try a slight tint and see how they like that ?
Sent from my iPhone using Tapatalk Pro
1992 1.8 8 valve Convertible GTI
2008 E93 335i N54 Twin Turbo
3 Kids
Suzuki LT50 Quad
( and the Mrs )
3 Kids
Suzuki LT50 Quad
( and the Mrs )
It does seem that the colour in OEM lenses are quite stong, the red tint I used on mine still flash as orange even with white bulbs so a light tint shouldn't be an issue
Current rides:
Doddle to do and makes the back end a lot tidier
Simply unbolt the fog light with a 13mm spanner and snip the wires, pull the wires back through their grommet and into the boot
Remove the bulb holder and you'll see one of the earths is now redundant as you've cut the other end off so remove it completely
Now just pull the spade connector from the reverse light and leave it loose
Fit the same size male spade to the fog light wire and plug it in the others place.
Swap the bulb to a red one and Roberts your mothers brother
Current rides:
Current rides:
