16vg60; Advice on last few things
You need a carb tank for the lift pump and you want a cabriolet lift pump for simplicity as the outlets are facing towards the front of the car and the connector is in the right place. If you get a polo version the outlets face towards the rear and the connector plug can be a pain.
Fuel lines fit easily at the back of the tank where the the rear seat bench drops down.
Mark aka funk-star at classic vw stocks the fuel reservoir (swirl pot).
http://www.classic-vw.co.uk/mk1-golf-cabriolet-gti-fuel-swirl-pot-4981-p.asp
I mounted the main pump in stock tray and the original fuel accumulator bracket can be modified (the holding bracket is round and the swirl pot is square, it just needs reshaping and something rubber to protect the sides - the original mounting points are as stock) to hold the swirl pot.
You just have to fabricate something to keep your fuel lines away from the axle as you will have 4 lines running from there.
Is you want any help just ask as I have done it recently on my G60.
Rich
Last edit: by Rich.
Thinking back to when my car was on the road I remember it hesitated slightly when cornering hard so I think there is an issue there which needs to be addressed and I want to ensure the engine doesn't get starved of fuel at any point.
I don't suppose you took any pictures of your build at all did you? I take it you had the standard rubber hose feeding the main pump from the tank, then pump to swirl pot, swirl pot to engine and engine return back to swirl pot and a return from your swirl pot back to the tank?
Be great if you had any pictures of how all this is plumbed together, thanks.
I do have some pictures, I was planning to do a guide.
Give me a week and I should have something.
I put the Corrado G60 fuel filter in the scuttle panel where the original one was as there are holes in the scuttle to accommodate the pipe work and also managed to fit my hydraulic clutch reservoir
Last edit: by Rich.
daniboy123 said
That is a normal fuel injected Citi Golf tank. The FI tanks all have an internal swirl pot built in around the outlet.
1983 Golf GT 2.1 16V with throttles/1978 Golf LS 2.1 ABF with throttles/2008 Citi Storm 1.4i/2007 Hyundai Getz - my daily
Where would I get a tank like that from? Thanks.
Website Manager
