Oil light flashing
(In Topic #195334)
Help!!!!!
I have a 1.1 formel e
the oil light has been flashing but I have checked oil and all is good
today it was flashing as usual I turned the car off , then when I tried starting it it wouldn't turn over at all and the temp gauge also started flashing so I left it ten mins and then it started but oil light is still flashing what could this be ???? TIA
check the oil pressure switch(es) on rear of head, and the wiring to it/them
Hot start issue will be separate to the oil pressure light issue. As above for the oil pressure switch problem
'83 1.3 Golf Driver GT - Project thread
Instagram - matt.semp
Sorry mazza411 I didn't quite understand that last post
But it does run like a dog when cold
Basically, the act that it wouldnt start until you waited about 10 minutes means that there might be an issue with starting when hot. Do you know what carburetor you have? (i.e weber or pierburg) sounds like possibly a problem with the choke mechanism or maybe it just needs a good tune?
But this issue is separate to the issue with the oil light flashing. That can be cause by many things, wiring being faulty, or the pressure switch may have failed or in my case, there is an internal issue within my clocks and the light flashes whenever it fancies
Thanks for the response
The choke mechanism is a bit crappy quite stiff and doesn't really work as it should on mornings the car rarely starts with joke out it's always off basically and its a Webber carb
Whet would I find the pressure switch to change it to see if it is that
Hmm, Ive not go a weber myself but know theyre usually more reliable than the pierburg one i have!
Im not entirely sure what the problem could be, does it run alright once up to temperature? and are the plugs looking a bit black? also, has it always been like this or has it suddenly changed?
On the back of the cylinder head at the top above the inlet manifold there are two sensors, one should be blue and one white i think, rubjonny should be able to advise you on the correct orientation of the switches and the wiring
depending on the age of the car you'll have 1 or 2 switches, with yellow and black/blue wires to them. the blue or brown switch is the one that does the light at idle so start with that one, make sure wire is clean and switch isnt leaking oil
Yes there's two and one of them does have a lot of oil round it didn't really kno y so that would be the first place to start
Thanks for all the help!
