1.1 idle problems
(In Topic #163248)
My 1.1 has always run great since I got it but recently upon start up it won't idle properly and loses all revs and cuts out, a lot of choke helps a little but still sometimes even with choke out it just loses all revs and cuts out, adjusting it doesnt really make a difference, i think this only seems to happen when I engage the clutch though but I'll have to check that.
Once warmed up it runs better but still idles a little low but doesn't cut out or anything.
I haven't really got around to checking it out yet, was going to adjust the idle screw and check all wires pipes etc are connected on the carb and check jets aren't dirty etc but any advice on what to check or what might be the problem would be great?
'83 formel e
It's strange because its usually fine upon start up but shortly after if I move off then depress the clutch it loses revs and cuts out then doesn't idle right so hopefully that is just the carb needing a clean
'83 formel e
Rusty Hookers Dub Club
Upon cold start up it runs with choke out but still when you move off slowly then brake and clutch it still loses revs and cuts out while the choke is still on.
Up at temperature it will idle okay with a tiny bit of choke (still isn't idling well though but doesn't cut out), too much makes it slowly loose revs until it cuts out and if I take choke fully off it cuts out too.
I've tried adjusting the choke cable on the carb but with no real effect.
I did notice a spring on the side of the carb which wasn't attached to anything and looks like it rests up against one of the throttle levers on the choke cable side, there is also a hole in this lever which the spring might fit into? Annoyingly I forgot to take a photo of it when I had the carb apart but I'll try and find one somewhere.
dan_73 said
check your idle cut off valve is working properly
Yeah i did wonder about this, Is there anyway to check if its working or not?
Any more ideas?
Ned
'83 formel e
anyone know what else i could try or what the problem might be?
'83 formel e
I'd remove, replace, check, check again and just tinker until I rule everything, but the carb, out.
Mine had an idle problem once due to the carb mount - is the clutch cable free moving and not pulling/trapping anything?
It has made a difference and is running better now but it still isn't quite right, at idle with the choke all the way in it will die, with it slightly out but without choke light on it idles and doesn't die but the revs go up and down, doesn't sound right and isn't smooth at all.
I can start it fine with choke and run but then all of a sudden will conk out when clutch in and no revs, even though the choke is still the same as when i started or how it was running fine just before it decides to die.
i haven't replaced the plugs yet, only cleaned them up etc so going to replace and see if that helps.
but anyone got any ideas? it's getting very frustrating now thinking it's fine then coming to a stop and it conks out with no warning!
would any of these symptoms point to the ignition timing being out? thought maybe that could be the problem?
'83 formel e
connected it back up and going to go for a run later so fingers crossed thats all that was wrong yesterday!
going to get some new pipe though and replace this as it looks a bit worn and cracked
'83 formel e
