Rack adjustment
Rack adjustment
lhasa said
jack up the front of the car and put on axle stands,slide under the car on your back then the left hand goes in the the left of the exhaust and the right hand to the right of the exhaust, takes a little time to get your hands in the right position.
Hold the spanner in the right hand.
I reckon you must be double jointed lhasa?! I was doing an oil and filter change this morning so thought I'd give it a go. Blimey, couldn't seem to get any where near the adjusters. 8O
Think I'm gonna have a word with my mate with the ramp and have a propper go!!
The adjustment only takes about 5 minutes it is the inital co-ordination with the hands to get in the right position is the hardest bin, hang in there Hairy.
I went to GSF and asked for a L/H track rod arm and R/H track rod arm and one R/H tie rod end, but was told that the part they sell does the L/H and R/H with locking nuts. I thought the R/H only had the locking nut. Anyone?
It's better to have them both adjustable anyway, because it makes it easier to centre the steering wheel during tracking.
I fitted the L/H side today but had a hard time locking the nut on the steering shaft, the nuts a hugh and I didn't have a spanner big enough. I managed to lock tight using 2 mole grips. The steering is much better now and the play has completely gone and I havn't done the other side yet! The steering wheel is steady at 70 mph before I had a little left to right movement.
What annoyed me today was that the locking nut was loose on the rack and split pin was missing on the lower ball joint!! Never again will I go to a garage.
Guest user
You can't get in properly with a spanner to lock the nut, mole grips is the only way unless the rack is out! things gets in the way!
I'm doing the R/H arm tomorrow.
I always track by eye, DIY is much better than throwing your money away to the cowboys.
Guest user
