NWM 6.1
NWM 6.1
are you even getting a spark? start witht the basics, take a pulg out rest it on the engine witht the HT still connected, get a buddy to fire the engine and see if theres a spark, if not do the same but with main coild HT on the engine, see if thats sparking, it should be big blue spark, if not then change it, then if its still not firing check you dissy cap/rota arm, then if its still not firing check your points gap, if its still dont fire after all that, make sure your fuel pumps ok, and you have fuel in it!!
alex.
Dont forget to hold the HT lead with your hand :shhh:
mk1 silver campaign totally standard lowered on coilovers magic tree vanilla
Just had a full outer body restore
HT lead
If in doubt, give it the lick test!  :)
This is what I like about this website, It does matter what your problems are, someone's always willing to help :D
Definately getting fuel, can see it squirting when pumping the throttle, getting a spark from main lead but not individual leads, adjusted the points but still no luck, dont think its the condensor cos i recently replaced it, cap and rotor are new also. :banghead:   What could it be? :dontknow:
Problem
Check to see if the little carbon spring loaded pin is in the centre of the dizzy cap! I once had one where it came out and of course, I got no spark either! Just a thought!  :)
You need to do a check to see if your points really are opening and closing. Turn the engine over (using a spanner on the crank pulley) and look at the distributor, with the cap off.
points!
Non't forget the lick test on the points!  :D
When are we having our next meet guys? Are we on 7.0 yet?  :dontknow:
I used to own a mk1 - well I've had 2 actually - YDU 720X & SMU 420Y. Currently I drive an 98 Scotia White Mitsubishi Evolution V RS…. fancy getting another mk1 someday :D
Sunday 15th or 29th would be good for me…. family committments allowing… I take it that we are still on Sundays?
Yeah.. I think 7.0 is the way forward now Kins!!
Dan
OK NWM 7.0 it is………. The SWM have a SWM 7 thread rolling so we better get moving.
Please see NWM 7.0
'Ere y'all NWMers
Anyone going to the Racing Car show at NEC  (14th/15th Jan) ????
Autosport International 2024
If Vicky Butler-Henderson is going, so am I
Mk1 GTI
B5 Passat Estate 5 SPeed
Riley 1071"S" Elf Mk2  (Bl**dy Hooligan machine!)
Bosch Lawnraker 32
I'm deffo going to autosport show. It's simply the best show in the country if you're into your motorsport. I think the lads at uni are sorting out a mini bus or something. Should be a good crack. :P
