Rallye
Website Manager
Hairyarse said
ETA for completion?
It'd be nice to have it ready for the rallye meet at the beginning of April but I'm not rushing it to make it for that.
Most parts are ready to go back on but there's still a few awkward obsolete parts that we've got to source, make or repair.
theres a great rake of great looking shells coming out at the moment, great to see
matt
Marketing Manager
1973 BMW 3.0CS "Helga"
1981 VW Golf GTi "Agolf"
1986 Ford Escort RS Turbo S2
1987 BMW M535i - 'Klaus'
Instagram: @ahmet_e9
Have you realized the steering wheel is on the wrong side of the car!
ABS pump tidy up…
and fitted along with new brake pipes and foot pedals…
Some new roof insulation panels cut and fitted before the roof liner went in… A lot easier than a MK1!
Bulkhead and behind dash sound deadening back in. Some of the wiring loom goes behind it and the rest goes in after it. Don't ask me why!
Rear loom in and rear washer, central locking vac pipes and pump. Had to make a repair to the loom where it passes between the roof and the tailgate as the wires break up from the opening and closing of the hatch over time. Common fault on mk2's.
Filling the cavities with wax oil. Sticky horrible job! And sticking new sound deadening pads back on the rear quarters…
Rebuilt turrets with new oem springs both front and rear..
Replacement of sticky felt pads that hold some of the wiring loom down. The photo below showing the rear abs sensor wires running under the back seat..
Started to reassemble the rear axle now but got stopped in my tracks as I need an 8" piece of 2" round nylon to push against the underside of the wheel bearing to oppose the force of the bearing press otherwise it'll just push the inner inner race out and destroy the new bearing.
I must remember to take my decent camera instead of using the iphone.!
Like cut a rear quarter off a scrap MK4!……
Rear arms and arb assembled and fitted. Standard bushes are obsolete so using powerflex black series…
Rebuilt the heater box….
New LHD matrix fro ClassicVW
New foam on the flaps!
New Sound deadening from Newton fitted but needed to be modified to suit the 4wd tunnel before I could then fit the front carpet, fit the heater box, the fusebox dash and then steering column.
Never managed to take many pics at this stage as I seemed to get zoned into getting it all back together. Some of the loom runs up under the dash above the glovebox so you have to lift the dash so far and then fit the loom to the dash before pushing the dash fully home whilst making sure all the vents line up and not trapping any of the loom where it shouldn't be.
Waiting for a speedo cable before I can finish off the top half of the dash.
Plans for next week……
Turn my attention to the propshaft as I'm going past the balalncers on Tuesday so will drop it off for balancing.
I need to put the exhaust downpipe and the front section of prop onto the engine assembly before wheeling it under the car as its next to impossible to get at the bolts for either once the engine is in the car.
Fit the sunroof mechanism and other parts to finish off the roof.
1979 mk1 Golf Gti (Dan)
2010 T5 Karmann Colorado
2012 mk6 Golf Tdi convertible
2019 Skoda Octavia Sport ( it’s Golf)
Latest progress includes fitting the fuel lines which involved a day taking the originals to a hydraulic hose shop to replace the rusty fittings on the original pipes. The hose shop also supplied new vac hoses and all the eared clips required.
Also fitted the pump and the tank.
Sunroof frame is back in and have mounted up the rear axle…….
Waiting for a downpipe gasket before I fit the motor but it should be back on 4 wheels soon
and
oh and
Fantastic detail as always Graham. I have to ask, are you getting at all attached to this one? Will it be hard to hand it back to the owner??
It won't be hard to see it go - jubilated will be the word but James who owns it only lives a couple of miles down the road from me so I'm sure we'll be convoying to a few shows together, so will get to see it regularly.
Where they are connected to the body there had been some electrolytic corrosion. The shields were also quite badly marked.
On the back side on 3 of the shields was a felt layer sandwiched by foil. The foil had virtually disintegrated and the remains of it can be seen here in the bin along with the pink felt!……
After removing the foil and the felt, they were put in the vapour blaster to give them a keyed surface and after drying stuck some aluminium discs using polyurethane glue to the corroded mounting points………
Stuck on some new foil backed heatproof felt with high temp contact adheisive…….
Then wrapped the whole shield in self adhesive foil tape to bring back some bling to the shield and to seal in the new discs and felt…..
First one finished fitted to the car…..
Quite pleased with the result if I do say so myself , considering the state they were in!
Only another 4 to sort out!
Hang on where's the evening gone?!
Life Member
Well done. I'm loving the updates on a different car.
