Jessie the tdi mk1 jetta (haldex conversion begining...) 12/09/17 update!
Here's a few pics
Jason my apprentice looking gormless!!
This is how we left her for tonight, good days effort I think!
Mk1 Jetta (Jessie) build thread here
View topic: Jessie the mk1 jetta (pd conversion) lots of pics!! - The Mk1 Golf Owners Club
T25 westfalia camper, 2.2 Subaru powered
vw touran 1.9 tdi remap, Bbs rep wheels , lowered, bla bla bla……… Wife's car
2013 Vw amarok 2.0bitdi, work truck……. www.jsgarageaberystwyth.co.uk
what intercooler and rad are you using?
also how did you find the gear cables, did they seem a bit long?
sos for all the questions just trying to do research for my own project
Old dubs never die, they just get lower
My intercooler pipe kit arrived today, top pipe was nice and easy to make, lower pipe was a bit more effort, I dropped my intercooler and a section of pipe off at the alloy welders tonight to get a 180 degree bend welded onto the end as I've had to cut the bend right down and now the clip doesn't hold tight enough and I know it's guna blow off! Once I've had it back tomorrow I will get it all fitted up a dim just waiting for my clip adaptor pipe for the turbo then.
Also trying to find homes for the n75, egr and shudder valve solenoids too, think in going to fit them under the rain tray and run the vac lines through a grommet into the bay, keep it tidy. Bora servo hose fits the golf servo nicely.
Wiring loom should be back tomorrow too
Tomorrow's list is
Run clutch pipe and bleed
Finish intercooler pipework
Fit rad and hoses
Fit boost and egr valves
Mabye start on exhaust……..
Today I managed to get the fuel system finished, run my clutch pipe along the bulkhead, wired up my reverse light switch, run the mk4 battery terminals and earth leads, replaced the dodgy wiring connections on the dash loom, replaced fog light and heated rear window and dashboard plugs as mine were missing or badly wired up!! connected the original jetta wiring to the battery terminals and started to do a systems check of all things original jetta, not a bad start, few bad earth connections on the rear lights and a few bulbs and all was good! Well I say all Is good apart from I have reverse lights on all the time! Think I need a new switch as if I unplug it they go off, Even checked the dash panel, temp gauge and fuel gauge work fine, illumination working fine, set the clock and even that started ticking away! Still awaiting my engine wiring loom, I was hoping for it today but should be tomorrow, awaiting my heater duct for the the screen vents as mine was missing then I can get the dash in, will be nice to have the interior all back together again, my new brakes arrived today, 256mm disks and vauxhall pads and brake hoses, I'm awaiting my calipers and carriers to arrive then I will get it fitted. All in all good progress for today, just awaiting parts now till I can continue……
Smudger
Few pics
Ecu mounted above fusebox and wiring running across heater box, new relay box and fuse box not fitted yet till I get the dash back in
Calipers been powder coated chrome, will contrast the wheels nicely
And my wheels
More updates tomorrow
Took 20ltrs of diesel into work this morning thought I better put some fresh in as it's been sitting a while and It only had 2 litres in it! PGot my intercooler pipework back today, all fitted, looks nice and neat, one small issue I found is that now it's back on the floor one boost hose is very close to the driveshaft, need to remake it and rotate the turbo for some more clearance. tyres also arrived today so got straight onto fitting them, 165/50/15 on a 7j rim, bit of stretch but not extreme, easy to fit the tyre but a nightmare to get to seat on the bead! Had to cheat and use a cheataha to get them on, balanced up tidy and got them on! My brake caliper seals and fitting kit arrived today, got them rebuild today and going to fit them tomorrow along with the new disks, pads and hoses. While I'm still waiting for my coolant bottle and a few other bits, I'm going to tidy the wiring loom up and get the bulkhead grommet fitted and get the relay board and fusebox mounted aswell, I also started to make my downpipe today, I've got from the turbo to just pass the steering rack, replace the plug on my wiper motor plug to the mk2 motor plug and get them adjusted, more tomorrow…..
Few pics
Wiper motor wiring all sorted.
More soon……
Sent my spare hubs to the machine shop today too, I've bought some track rod end reversal bushes, as I'm running it quite low I had massive bump stear, so these bushes fit the tre from the bottom to give a more positive steering feel.
Once there back I will fit the new bearings, hubs, brakes, and fit the helper springs onto the coilovers, and get the ride height, tracking and camber all setup then. I can see the finish line and can't wait for the first test drive!.,
Still no heater vent ducting, so still no dash fitted! I hope it arrives tomorrow, can get the dash fitted tomorrow night if it arrives in the post. Then my interior is done. More tomorrow………..
