JB's Blasting Cabinet mk2 now making mk3, other shed content!!!
Sticker Pig
I will give you a pack of jellies in exchange. This si because the last time i saw you your belly looked starved of Jellies and that is unacceptable
Good job there mate…
Diesel Possessed
A97JCE
Feeby
A97JCE
Feeby
What would you say the blaster could get through attached to a 10cfm compressor?
http://hackaday.com/2006/07/05/diy-powder-coating-gun/
Just need to figure out a way to charge the powder!
This doesn't seem bad, you get powder too.
Powder Coating - Paints & Coatings
I'll stop clogging up your thread now :p keep it up!
so this is what ones side did look like
as you can see it's a right mess and not making use of the space very well so a bit of money and effort later
i have finially mounted my vice after 3 years, so happy right now!!!
also i didn't relise i had so many 1/2 tins of things on the shelf
also the mk2 sand blasting cabinet is in the bin! but all the parts were kept
mk3 is now in progress!
You ordered your powder coating stuff? A mate offered me a "complete powder coating outfit" today, not sure what that entales mind.
If you want the PSD Boot Sticker file, it's here: Boot Sticker
it was a little small a rocker cover was the largest thing i managed to do
it wasn't a complete seal around the lid, hardly leaked but not perfect
the vision panel wasn't good, the size of the box restricted what you could do with it so decided on a new design
all in all it was successful and a good idea but could be improved, so i have done
total extra cost £32 on timber from B&Q but so happy with it, should be the business
so the size altho looks bit is no bigger in floor space than the RUB (really useful box) but just taller
fits like a peech in the space, raw mdf form
then removed and the holes cut in the front to take the gloves and extraction, and undercoated (trying to use my 1/2 tins up)
had 1/2 tin of red so thought let do it
then this evening i mounted the door and everything else, looks the business
2 lights installed, outdoor ones that were in the RUB just needed some new wires
underside of the perspex i gone for some asitate again to protect the perspex, i will get a peice of glass eventually but this will do for now
