First Mk1/vehicle Project ever
(In Topic #205928)
Garage clearance 1979 Golf GLS freebie in need of some love and attention!
You can get yourself into a whole lot of trouble if you go off half c0cked.
Do take some more pictures from all over the car, under the bonnet and from underneath if you can. Let use have a look and we might be able to guide you.
If in doubt ask first.
Also I suggest you join your local region and maybe you'll get lucky and someone near you can come around and give you first hand advice!
So I levered a screwdriver underneath the joint in the bonnet and it wouldn't budge. Then I levered it a bit more and saw there was some sealant of some kind running the whole length of the top of the wing. I cut this seal but still no movement. I then got a heat gun and heated inside the wheel arch near the passenger door and put my fingers under the top of the wing and pulled. It popped the front end came away and after a bit more heating and pulling the whole wing did what I thought it should have done 60 minutes before and came away!
Fair play to you for having a crack at it. The welding rate doesn't sound too bad.
Any pics of the interior, what condition is that in?
I take it the £30 for 3 hours is to fix underneath the near side wing? If so one problem you may find is that the car probably has many places that will require attention, so if you can't do it yourself, it may be cheaper to strip the entire car and get everything sorted at once.
Either way good luck with the project. Learning things as you go can be immensely pleasing.
Matt
