'90 Cabrio Karmann
(In Topic #196984)
Hello all,
Small introduction of me and my '90 Cabrio Karmann
Over 20 years in the aircooled scene with a high end resto of a '68 VW fastback
Currently restoring a Westfalia Hearse trailer to again a very high standard
Used to be a big parts trader regarding these particular cars - recently sold 99 %
Urged for something new I bought a '90 Cabrio Karmann
The idea is to keep it running - make it better / usable
Some pictures for the moment before I get to the MOT station for a second check up of the gas tank since it has been converted to run on LPG
OG black with Fifteen52 16x8 ET 30 rims - bit lowered - smoked side markers - debadged rear end - red taped rear indicators and a full leather interior with Corrado adjustable seats
Still some work left to do once it is back from the LPG inspection
BerT3
BerT3
Those wheels look fantastic, not seen them before, are theybthe same make as the Scala/Snowflakes?
Looks nice already
Those are bought from the USA - made to order
http://fifteen52.us/featured/18-rml-snowflakes-available-at-gunther-vw/
Bought already a lot of parts to rectify some things that bothered me:
- Glovebox door - damaged hinge
- Ashtray + cigarette lighter - broken clip
- Console for the gearbox tunnel - cigarette burn
- Fresh air vent - broken fin
- Blanking cover for the electric sunroof switch - missing
- Horn button small attaching pieces - broken
- NOS fresh air grille set in front of the windscreen
- Sun visors - non-screw type and out of shape
- Small cover on the B-pillar - pecs missing
- Seat rail cover - cracked
- Hand brake cover - cracked
- Fuse box cover + cover on the other side - missing
- New floor mats - dirty
- Rear parcel shelf - speakers installed by a non-technical PO
- New rear trunk carpet - missing
- Spare wheel + tool set with attaching rubber and the big nut - boo box installed in the spare wheel recess
- Rear trunk 3-piece cardboard set - modern speaker carpet glued over the OG ones
- Clipses to install the above - missing some
- New seat slider clip set - damaged
- Rear seat release pull - broken clip
- Collected the OG rear trunk lid - will be put in storage - complete with all the 4 badges in black / silver
- New gearbox bushing set - sloppy shifting
- NOS gearbox shaft boot + NOS front bushing + NOS heat shield for the boot and a NOS front protection plate - all were missing
- NOS black window surround joint trim
- NOS side Karmann Badges
- New bonnet stay clips - convert back to OG bonnet stay instead of those pumps
I am pretty sure some small things will pop up when I install these though…
BerT3
BerT3
Lovely looking Cabby, I've always been a fan of those wheels
Photo of the pile of parts - once I get the car back from the LPG company alL these will find it's place on the car
BerT3
The list got longer:
- New door speaker pods - the LHS original one had 2 small holes drilled in
- NOS L+R outer door window scrapers
- Repro parcel shelf clipses - will be up for sale since I found a pair of NOS ones
- NOS Front numberplate holder in case I want to go back to stock
- New Hella rear numberplate lights
- Various very small rubber pieces for the doors
- Every NOS rubber to change the front hood pumps back to its stock rod
The LPG is MOT'ed - hope to collect the car next week and start changing out all of collected parts
BerT3
BerT3
Have the car back - drives perfect now - has a MOT for a year - the LPG installation has n MOT for 8 years
Lots of work done on the engine:
- New carburettor - the wax thermostat was only one of the damaged pieces
- New dizzy cap + leads
- New correct lower temerature rated spark plugs for the LPG
- Removed an electric fuel lock and replaced with a pressure sensive fuel pump - LPG setup related
- Timing belt repositioned - was 2 teeth off !
- Set the timing
- General adjustments to make sure it runs like new
At home I did some work so I could stripe of some jobs from this list:
- Small cover on the B-pillar - piece missing
- Spare wheel + tool set with attaching rubber and the big nut - box installed in the spare wheel recess
New list:
- Leather gear know to replace the golf ball Kamei one
- New corrado LHS height adjuster handle - already found
- New door window handles - all 4
- New seat catch bushes
- New head rest tubes
- New OG wind deflector without hols or damaged fixtures
- New B-post seals
I also like a set of rear badge refurbish decals in bright chrome
Photos later
BerT3
- Set the timing
New list:
- New B-post seals
Photos later
BerT3
Last edit: by BerT3
The list got longer after driving in the rain this morning- foggy windscreen reveiled a non-functioning heater
2 speeds works but when turning to the third speed it quits
Turns out I do have a USA trim panel for an AC car - I will install the correct one
The smal plate with the LEDS behind it is damaged as well
While removing everything after I sourced a heater setup with heater controls I'll replace the dashboard trim too since it has cracked fixing holes in the corners
PO's…
Updated list:
- Under dash heater with heater controls
- Heater trim panel for a regular non-AC car
- Trim panel mount with LED's
- Dashboard surround trim
- New OG wind deflector without holes or damaged fixtures
- New B-post seals
Still some work to for wat was supposed a finished ride - I guess everyone has different standards
BerT3
PO's…
Updated list:
- New B-post seals
BerT3
Some new parts are on my way to be fitted - some small bits and bobs that annoyed me - either condition or just damaged
- NOS door top big caps - one was scratched
- The dual horn setup - one was damaged - the other one a generic one
- Correct - Non-USA dashboard parking brake light
- One lower seatbelt B-pillar cover - that one was damaged
Noted that the front grille has later MK2 fog lights in there - these are recessed instead of being flush - I might address those in the future since these function
BerT3
BerT3
Making real progress, not too much left on your list now. are you going to do enough miles to justify the cost of LPG then?
I will - using it daily to drive to work - it's MOT-ed on regular non-classic car number plates so I can use it anytime I wantRichardHall said
The LPG is over 2,5 times cheaper the mile than my Mitsubishi diesel and 3 times cheaper than using 98 octane fuel
BerT3
Last edit: by BerT3
Bought / won some pieces on Ebay to replace the non-functioning heater setup
Bought a very nice and complete heater front trim panel with correct light cluster - knobs and switch
I noted the bottom right corner of the dash panel wasn't sitting flush so checked and saw that part was broken
Bought a very nice dash panel on Ebay as well
Earlier this week I bought a complete heater setup with sliders - motor and resistor - plenty of parts to change out to make it work
And finally bought a full set of B pillar seals + covers and end caps just in case I ever decide to change out the LHS A pillar seal and those carbon foiled B pillar covers
I am getting there to use / keep it for another 25 years
Still can't figure why the previous owner(s) neglected so many small things…
BerT3
BerT3
2 recent photos - needs a good clean though
BerT3
BerT3
Wow, looks stunning!!
I've always loved those wheels, 15-52s or whatever they're called? lol
Now that's what I call a Black Cabriolet!
Have you made many changes to the interior and which brand of coilovers are you running and how have you found them day to day?
Regards
Regards
ConvictGTI-No.1983EW said
Now that's what I call a Black Cabriolet! Have you made many changes to the interior and which brand of coilovers are you running and how have you found them day to day? Regards
The only deviations from stock are the Corrado height adjustable seats - the full leater retrim
A Porsche steering wheel and the centre console with 3 gauges
And a radio of course
The coilovers are height adjustable Weitecs - they ride a bit harsh yo me but I do have a Mitsubishi Space Wagon to compair
BerT3
Some parts arrived which I installed this evening
Striped some jobs from the updated list:
- Leather gear knob to replace the golf ball Kamei one
- NOS head rest tubes
- New B-post seals
- New caps on the front chock towers
- New engine bonnet support seals and spacers
- A badge refurbish set
- New cigarette lighter with OG wiring - the light itself didn't work
If someone knows an answer to these posts feel free to enlighten me :)
Regarding the head rest tube
http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=technical%2Fbodywork-fittings-and_2%2Fhead-rest-guide-removal
Regarding the choke:
http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=technical%2Ffuel-systems-and_3%2F2e2-first-7-seconds
Regarding the position of a small piece on the gear linkage:
http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=technical%2Frunning-gear_2%2Fgear-linkage-stone-chip
BerT3
- New B-post seals
BerT3
Booked a refit of the LHS side cable to rectify the bubbling roof
Fingers crossed
BerT3
Fingers crossed
BerT3
