Bike engined mk1.
(In Topic #196733)
Big twin instead of your normal 4 pot
Hi folks,
I'm just condidering a Mk 1 engine conversion, I was going to go down the busa/blackbird/zx12r route, front engined rear wheel drive, but people seem to think there's not enough torque, soooooo, I was wondering if anybody has tried sticking a big twin in there instead, Ducati/RSVP/TL 1000 ect…? Could be interesting, or is there a reason I've never seen one?? Thoughts please anyone?
Cheers, si.
Cheers, si.
It didn't seem to be a problem for H R Engineering's Hayabusa bike engined RWD golf
And you could also bolt on a turbo
Yeah, that seems to be the easiest option, the busa engines also seem to be the dearest used too, honda blackbirds and kwak zx12r seem to be a fair bit cheaper. thought about a twin because it's a bit different, and torquey and grunty, more low down torque… Or maybe a triple….. Hmmmmmm so many options! I've emailed hr engineering last night so I'll see what he comes back with….
find a triumph rocket engine shouldnt be short of torque then.
any bike engine will be down on torque in a car because its designed for something that weighs 200kg.
the thing id consider is do you like driving something something revvy like a type r and work well on a track or do you want to cruise and be able to stick it in top gear and pull because you will not find this from a bike engine.
Triumph rocket was actually what I was looking for last night, mind was going over all the bikes I could think of… There was one on eBay but it's in America…maybe I need to be sensible a stick with a vw engine and tune the nuts off it, would be a much cheaper option perhaps…..
Id stick to fitting a car engine just fr the sake of power and torque.
If you got a bike engine running 200bhp v's a car engine at 200bhp the car would have more torque and a lower Rev range.
Then again if you wanted something that sounds awesome at 11,000 rpm then got a for a flat four bike engine.
For me it depends on what your planning on using it for.
Bike engine for a show car with track use.
Car engine for easier conversion, more bhp and torque still do tracks and shows.
Don't get me wrong a busa turbo will put out plenty of bhp but at what cost compared to a 20vt?
But you would get a 6 speed sequential gearbox for less than £10k!
if you use a rear diff with a relatively low gear ratio then the lack of torque shouldn't be a problem.
I had considered building one myself. Was planning on using a Subaru rear subframe and diff etc. you can get a number of different ratio diffs depending on the model of scooby. Combined with a slightly smaller wheel/tyre size it would effectively lower the gearing and provide greater torque to pull you along.
The Red Rocket! My Mk1 Tdi Build.....
My VAG family:
1982 Mk1, PD130 Tdi, 6 speed, ongoing project, to be my daily driver (one day)!
1983 Mk1, 1.8 Gti, stripped out, ongoing project, track car only.
1990 Mk1 Cabrio, 1.8 8v Turbo, G60 ECU, long term project (17 years so far)!
2008 T5 LWB, 1.9 Tdi, to be converted to camper when I've finished using it as a van!
1999 Audi A4 Avant Quattro, 2.5 Tdi, currently off the road, more work required.
2010 Tiguan R-Line, daily driver.
My VAG family:
Cheers Kev, thanks for the advice, very helpful. My heads a bit battered with it all now, I'm now thinking sticking with a car engine, just to make life simpler, was actually thinking of a Skoda vrs motor, or still tempted by a type R… Would be quick with either I guess but very different power delivery, I like the idea of a screaming type R motor I must admit. Time will tell I guess, I'll let you know how I get on! Lovely build by the way mate, looks gorgeous.
