The original one & only Gulf Golf 18 years of ownership
The Gulf Golf April 29 years old and nearly finished!!!
Speeding is like masturbation, everyone does it ,but it's not something you should record and put on the internet!!
smudger1980 said
They look smart mate.
Thinking that they will look good peeking out behind the black(or white) Compo TH's
Last edit: by collo16v
smudger1980 said
Seem reasonably simple jobs mate. No way you could them yourself?
I could trouble is car is miles from anywhere and if I hit an issue means putting it away going to get whatever I require coming back etc ,garage I use in Margate is brilliant and cheap,as Jim loves a project and something different from the everyday cars that are his bread and butter. He did all the work last summer for me and could not be happier with it!!
collo16v said
Comtemplating going 1.8T route as I have all the parts availlable from the MK2 Scirocco we broke earlier this year
I thought you might get the itch mate
Go on you know you want to
ARB removal is a few bolts
Good luck
smudger1980 said
Filler neck and tank straps are fairly simple jobs to do mate. Are they the ones that are ready shaped or not?
Good luck
Nah they are flat so guess I will have to bend into shape?
smudger1980 said
Yeah, I haven't personally done it but I think it will be a case of trial and error under the car using the fuel tank to help you along the way with persuading as well as with a vice
Sounds like fun lying on your back in the drive!!!
smudger1980 said
Are the bits at each end where it attaches to the car bent into place ready to go or have you got to do those as well?
You know what I cannot remember now been in the packaging so long!!! ah well I have all enginnering facilities to hand so will manage ok just remembered got my bonnet risers to fit as well
Good luck.
smudger1980 said
You'll be fine mate. Post some shots up of it when it's done
Good luck.
Will do got to blow the cobwebs of it 1st!!! not been out since Aug 2012 and not started since then either
