Sold
Good news = car passed mot!!!
Bad news = can't track it due to been lowered!
Ok news = brakes passed all checks but agrees the pedal travels a bit before they do anything then work great.
I'm getting the paintwork samples today by a "block" reader then I'll be having a few parts painted up as a put me on for a little bit. Hopefully that getting done next Saturday.
Interior coming out to be cleaned and a new interiors going in, once the weddings been finished.
I have the same problem with the lowered issue.
You need to find a tracking place where they know cars, I know that sounds daft, but I managed to find a place where they can adjust the angle of the top arms on their hangers to fit over the tyres at around 2 o'clock and 10 o'clock rather than at the usual 1 and 11 o'clock positions. They then use a tape on the centre of the rear wheel rather than using the rear hanger.
I've also been told that laser alignment can do it as thy attach to the wheels rather than hanging stuff. I've also been told that Quik Fit now have laser alignment in some locations. Might be worth giving them a bell?
Otherwise it's down to strings and chalk on a flat level surface, which is a pain in the bum but doable.
I find the same with brakes that have been bled using a bleeder system. I usually use a vacuum bleeder then get a friend (read tramp who needs a tenner) to push the pedal lots for me to bleed them manually afterwards. Seems to stiffen up the pedal a bit more.
Looks good!
Ian
Kwik fit branches can have the hunter tracking stuff which is good for lowered cars.
I might have a lead on a lad who races mk1 golfs so it will be set good.
I bled the brakes in the end with a pressure system via the brake bottle but I'm going to run them and see if they improve as it's all new components
Taking my new mk6 golf interior along to weld up while I'm polishing car up.
Then just needs tracking and new wheels fitting.
It's gone from slow progress to full steam ahead the end is in sight!!
Not fully finished the rear seat yet but half hour Saturday will finish them off.
Where they a pain to fit?
Yes a pain but no one seems to have done anything different with regards to rear seats so I took on the challenge.
Need to plan some shows for this year now.
Not done the show scene in years so have to try find out all the info.
I'm near the Donny show the owners club is going to do will put my name forward for that.
Let's see how the next few weeks go and I'll see.
I take it the clubs having a stand?
The money pit mk1
mk1 daz said
I'm going to manually set the tracking as a need to drive it to a place.
Let me know what settings you end up with for the tracking will you please?
Toe, Camber etc.
I really need more info on that interior too
Looking good.
Ian
I took advice off club gti for tracking settings and went with -1 camber and 0 toe
I had to help them set it up as they didn't know how to adjust camber but the golf was older than the lads doing it so that was done at 9am.
Two and a half hours sanding the bonnet and the passenger wing, just need to do these bits to get me through till winter.
The money pit mk1
Also popped out the rear window and took off the zender spoiler to fit the black window trim sticker for the more original look.
