Sold
Hubs now painted red.
Apart from that I've got boxes of bits to put back on car when I get a day off.
Rebuild kits turned up
Just the cv boot left to take off, a clean up then start to put all the new parts back on.
Got the calipers rebuilt with new seals and pistons yesterday.
So can crack on now.
mk1 daz said
Caliper brackets have turned up today.
Need pics!! Fresh calipers always look good
Painted hubs with new bearings pressed in.
A little bit more progress this afternoon but it's left me only two hours to fit a bathroom….
Still got to connect the brake line but going to change all the brake fluid while it doing it.
I replaced the cv joints how the previous one was fitted but it appears the previous person didn't fit the c clip or the two other washers on the driveshaft to stop the joint slopping about.
I didn't see them in the box of bits till I was trying to find another big washer for behind the cv joint but.
It's all to come back off now to fit them.
Matt
pazwaa said
Was the calliper rebuild easy to do?
Matt
Depends on your skills ha ha
Basically take out the old piston (you can use an air line where the brake line plumbs into but I prised it out and got some grips and pulled it out.
Take out the dust seal, then the fluid seal.
Clean them up mint, the barrel and the two grooves the new seals sit in.
Fit new seals with lube supplied and then ease piston in.
You get new rubbers for the slider pins too.
I wasn't going to do it but the rebuild kit was only £30 and I'd rather build it right.
That has taken about an inch of sideways movement from the cv joint sliding up the driveshaft.
So front still needs.
Cv joint washer buying
Brake lines connecting
Horn earth connecting
Adjust steering rack to get tracking somat like before going for tracking as it's like duck feet!
Upper strut brace to go back on
mk1 daz said
Matt
Thanks for the info, doesn't seem too bad. Do you need any special tools to get the pistons back in?
pazwaa said
mk1 daz said
Matt
No it will slide back in easy just make sure it's square or it won't push in.
Need to press new wheel bearings into the new discs, then paint and refurb the mk4 callipers. New handbrake cables and brake lines to fit too.
