My MK1 project
(In Topic #192394)
1.8 20v turbo conversion
Hi
This is my 1981 MK1 GTI i collected last week.
The plan is a back to metal restoration of the shell, keeping the outside mostly standard looking, with chrome bits and bobs, maybe not a standard colour though!
Will most likely put a 20v turbo engine and gearbox in, custom and comfortable interior of some description.
She is in need of a lot of work, pictures to follow so i have started to build a turn over jig today!
Last edit: by Nikstar
Looking good Nik, look forward to more updates. The roll over jig makes life much more simple!
Andy.
Andy.
An interesting sounding project. Definitely a good idea starting with a roll over jig, makes life so much easier (and it will most likely still be a hard slog )
Matt
Matt
Hi guys,
Little update from today, After spending most of the morning sorting out why i had no electricity in my garage i finally got started with removing engine and gear box.
The engine and gearbox are now ready to lift out and i have all the front suspension removed.
I then built up my new engine crane in preparation for the big lift. I couldnt help having a poke around some area of the car that i have seen people having rot problems this was the result!
Its amazing what waxoyl will cover up, i didnt do any more poking for today.
Cheers Nik
Cheers Nik
Is that the front of the rear arch? quite a common place if so!
Its the rear wheel arch, I belive its the rear chassis rail hole in the side and bottom!Melteddrummer said
Comes out easier underneath but you can do it either way.
Good progress!!
Good progress!!
I would seriously weld some diagonal bracing onto your rollover jig, there's a lot of leverage working on those central welds, wouldn't take much imbalance to break.
I'd love to be able to weld like you though
There are a couple of upgrade I will be fitting to the roll over jig before I actually roll it over. I am glad you think my welding is any good, time will tell how good!
Looks solid.
My red MK1 is awaiting engine removal and lifting up on a jig itself, I will be following your thread with interest.
Been a while since my last post, lost a little motivation on the mk1 and due to other things in life not that much has happened, but i am back working hard.
Here are a couple of pics of whats been repaired over the last few months.
From this
To this
Passenger side floor repair
A little modification required to get lower windscreen repair panel to fit. I will do a test fit of windscreen before fully welding panel in.
From this
To this
Wow. That is a serious amount of work you're taking on. Well done so far…
My Build Thread
Cheers, just looked through your build and well done to you sir, your mk1 is looking well!
Thanks. It is coming along, but didn't need anything like what you are undertaking.
It is interesting to see the work that goes on in threads like this as it makes it all look so simple for when I need to do it 10 years from now!
My Build Thread
