My first Golf - 82' gti Black
Bought my first golf and going to keep track of what I'm doing on this :)
I also went over a few bits of surface rust in the engine bay and also did the top of the slam panel
Don't worry about the little bit i have missed I'm taking it back to get welded as there is a small pin hole there.
Should get the sound deadening layed down tomorrow….. finally!
Last edit: by MarkkGardner
I changed out my rocker cover and gasket as the old gasket was leaking so i have alot of oil to clean up in the engine bay at some point
looks alot better than the old scabby cover that was on it before after this I also re-adjusted the clutch cable as I had heaps of free play in the pedal.
Next on the list after my interior is back in is to get the engine bay looking nice this is a job I'm not looking forward too. I think I'm going to partially stip down the engine and send bits away to get anodized and zinc nickel plated.
What sounddeadening are you going for?
1982 - Mk1 Golf 2.0 AGG 8v - 158 HP / 202 NM
_________________________________________
Thanks!Hurtig said
Top work
I went for silentcoat its was pretty cheap on amazon, I will let you know what its like when its all in if its not quiet enough i'm going to buy a sound deadening kit on vwheritage buy the looks of it its just big patches that go in the foot wells and on the transmission shifter area
Next task is to get all the interior in once that small pinhole has been welded up.
Looks really good!
How much did you buy to do this install? Really want this done to mine
Re:
I bought one box on Amazon thinking it would be enough as it said in the reviews "enough to do a small car" should of measured what it would cover than take other people's word haha so ended up having to order another 3 boxesHurtig said
Top work on the sounddeadening
Looks really good!
Sent from my SM-G930F using Tapatalk
Re: Re:
Looks really good!
And I used about 45 sheets of 187x265
They were from Amazon and are silent coat the bigger ones are a bulk buy kit and the smaller ones come in packs of 30
If you want to add a bit more sound proofing try some dodo mat on the top of the silent coat on the floor panels and across the boot area. Expensive but worth it.
Inside the door panels lob in some 5mm self adhesive foam as well. Helps to stop noise too.
I also use some car underlay under the carpet too. Again just helps muffle noise from the road.
Looking good though so far. Next thing you'll be adding loads of speakers too.
Ian
Re:
I'll see if I'm happy with the noise when I have the interior in and might have to upgrade from the factory size of speaker I thinkborednow said
Nice work mate.
Ian
I also found out that i need a bit of welding done on my scuttle panel. The rust was hiding underneith the sound deadening thats on it so I stripped off the sound deadening and found this hopefully these are the last holes I find on this car…
But on the plus side I have my car booked in to get the bolster redone and the bases of the seats re-stretched next week and i've also booked my car in to get the boot, rear quarter pannels, wing and the sill at the bottom of the door resprayed as my door hinges are worn and door drops (new hinges are on the way)
-Zinc primer
-Seam sealer
-Hammerite
-Sound deadening
Then will paint the sound deadening black so it looks oem
Now just to put a few coats of hammerite back paint on top.
I also got my Seats back from getting the bolsters redone, In the end i got 3 bolsters redone and a new top layer of foam put over the full seat. The seats are so much comfier now only problem is that the new fabric is slightly darker than the original material on the seat .
I think im going to have to use some tigerseal or something like that to stick the carpet down in a few places as when you put your feet down it pulls the carpet out as you can see at the bottom right hand side of the photo.
Next- Get the underside stripped and reundersealed. This will be getting done on 26th so will post updates as I go along to inspect it through each stage.
I'd check that first
Re:
That could be my problem haha might put some foam underneath the carpets too just in the footwellsHairyarse said
The carpet pulling out at the side can often be due to not having the OEM soundproofing in place - i.e. none at all or some new stuff that's thinner.
They sent me photos of it with the raptor on but there pretty rubbish photos so ill hopefully get the car on the ramps next week at some point and take more photos of it .
I also got the mid-box cut out and a straight pipe welded in place so that it can sit higher in the exhaust tunnel as the mid-box would not fit in the exhaust tunnel and it sat really low and this will be a problem when i come to lower the car on bc racing coil-overs in the next couple of months.
Im also dropping the car off to get parts of the car resprayed I will post pictures of this as its getting done also.
parts in getting sprayed are:
the whole boot
sunroof surround
rear quarters on both sides
front wing
door jam
Im hoping to have this all done by mid may so I can have the car ready for volksfling at the back of Edinburgh at the end of may where there is a mk1 owners club stand that I should be on if all goes to plan
dropping the car off on sunday for paint
