My car audio install
no criticism, just wondering.
I have some kit to fit in my tin top at some point but am having headunit and placement decision issues…
anyway the air has to go in first.
1982 3 Door - 'BRO' - gone to pastures new
1990 Clipper Cabriolet - Jet green metallic
RichG60, I would consider selling the other pods, however, they took me days to make and £100 each to trim up.. That said, given the cost of the standard plastic ones second hand on ebay, I think the 6" pods would be a much better buy. You will get more bass than the plastic pods, but please bare in mind that this depends on lots of factors. The ability of the driver to play low, the ability of the door and card to play low (ie prevent any negative wave cancellation) the speaker cable, amp and head unit etc etc.. If you were going to fit these to a standard door card, you would have to dynomat the door and the rear of the door card and even then you will get a lot of negative wave cancellation. I made my door cards twice as thick and still struggled.. Don't get me wrong, they work well, but you need to understand the limitations of what you are fitting them to. People often ask "which speakers are best for my mk1 golf cabriolet?".. Well the answer isn't really as straight forward as that as the problem is the speaker box more than the driver itself. In this case the door and door card. So, as I have said before, its like saying, "which tyres are the best ones for a trip to the moon in my mk1 golf cabriolet?" Give me a call by all means and we can discuss audio and what you are trying to achieve and I will help you where I can.. 07861801582
Unityneil said
ARe you attaching those to the door "card", I always tried to affix mine to the metal. hiding the fixings behind the driver or bolting in from the rear.
Been thinking long and hard about this Unityneil.. With the 6" drivers and pods, there was not too much weight or inertia caused by the drivers. So I think I got away with it pretty well using the more solid door cards, popper fixings and butyl pond liner repair tape bonding material.. All of which will also be utilised in the 8" driver set up.. However. I think you are right. I am going to have to use some kind of mechanical fixing.
I do like the screw from the back idea. I will see how much room I have and whether or not the inner door skin and pod line up at suitable locations. Failing that, I have bought some rivnuts and an installing tool so that I can if need be do a nice professional job of making permanent anchor points to bolt too from behind the driver itself. I may even use a combination of both if need be. But I just wanted to say that you got me thinking.. I knew in my heart that you were right.. I just don't like the idea of drilling holes in my pride and joy.. So its gotta be neat and tidy. I will keep you updated on the results.. Cheers..
Website Manager
Hiding the ipod/media interface wasn't an issue, but having access to the memory stick would be. So I decided that I would use a good quality USB cable and fit it in a suitable blank in the dash. The obvious one for me was where the choke would have fitted had it had a manual choke. The blank seemed like a suitable size and in perfect position but when I removed it I realised that it wouldn't be as simple as just making a hole and fitting the cable through. My initial brief was not to damage the car in any way, so once I saw that there was only a small hole in the dash where the blank was held in place from behind by a screw, I almost gave up.. But.. With a fresh set of eyes the following day, this is what I managed to do.. I bought a second hand blank off ebay and modified it as per the following pics..
